Johnson 88 Spl not revving up consistantly
Termite
I have a Johnson 88 that won't rev above 4200 Rpm even when not in gear. When travel accross the lake it pulses, like it isn't hitting on all 4 cylinders. First thoughts were fuel problems. I have been through the fuel system from tank to cylinders. All good or parts replaced. 4 new plugs, all coils and wires check good with an ohm meter. Don't understand how to check power pack. Any suggestions?
do not rev the motor that high in neutral...you can also do a check of each cylinder with an inductive timing light and see if you have a miss..
check the compression and make sure the fire will jump 7/16 with a good spark on a gap tester..
When you have this pulsing scenario, does that mean you have a sharp instantaneous drop and gain of rpms (ignition) OR is it more of a gradual lowering and increasing of rpms such as one might experience when starting to run out of fuel, then switching to another tank (fuel)?
I'm aware that the fuel primer bulb does not stay hard when the engine's running (normal)... BUT... does it collapse in on itself (go flat) or start to?
If so, be sure to check the following:
(Fuel Anti Siphon Valve)
(J. Reeves)
Many of the later OMC V/6 engines incorporate a fuel restriction warning via a vacuum device attached to the powerhead. If the engine overheats, or if you have a fuel restriction, the warning is the same.... a steady constant beep.
NOTE... Only the V/6 & V/8 engines have the above "Fuel Restriction Warning". The warning horn will not sound on the other models.
The fact that a engine is not overheating, but the warning horn sounds off with a constant steady beep, and that the rpms drop drastically would indicate that the engine is starving for fuel due to a fuel restriction. Check the built in fuel tank where the rubber fuel line attaches to the tank fitting. That fitting is in all probability a "Anti Siphon" valve which is notorious for sticking in a semi closed position. It will be aluminum, about 2" long, and the insides of it will consist of a spring, a ball, and a ball seat. If this valve exists, remove it, knock out those inner components which will convert it to a straight through fitting, then re-install it. Hopefully that cures the problem.
The above procedure will cure a restriction problem with the anti siphon valve as stated. BUT, it may also allow fuel to drain backwards to the fuel tank when the engine is not running (siphoning backwards) due to the fact that the carburetors/fuel pump etc are higher than the fuel tank. This condition is not an absolute as the valves in the fuel primer bulb usually prevent this backwards siphoning problem. However.... if this does take place, the cure would be to install a new anti siphon valve.
NOTE: There has been cases when the output valve in the fuel primer bulb would come apart, and the inner portion of the valve would actually reverse itself and be drawn back into the primer bulb's output valve body. This in effect would create a shut off valve and result in a fuel restriction. If this is the case, you should be able to feel something laying in the bottom of the primer bulb when held horizontally.
And as other members have suggested above..... checking compression and spark is the troubleshooting place to begin. What are the psi readings of all cylinders?
Compression should be in the 100+ psi area and fairly even..... and the spark (with all plugs removed) should jump a 7/16" gap with a strong blue lightning like gap, a real SNAP! Does it?
(Spark Tester - Home Made)
(J. Reeves)
You can use a medium size philips screwdriver (#2 I believe) inserted into the spark plug boot spring connector, then hold the screwdriver shank approximately 7/16" away from the block to check the spark or build the following:
A spark tester can be made with a piece of 1x4 or 1x6, drive a few finishing nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere. Use small alligator clips on the other end of the wires to connect to ground and to the spark plug connector that exists inside of the rubber plug boot.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
