"Hi I have a 85 HP Manual tilt
"Hi I have a 85 HP Manual tilt 1980 Johnson I bought used. It is extremely difficult to move it up or down. I hear a squeaking noise when I'm moving it. I can't get any grease thru the two fittings that feed grease to where it pivots on the shaft. The fittings are OK grease went thru when I took them off. I have 2 questions they are: There is a cylinder that is attached to the motor and opens and closes as the motor is up or down, what exactly does this cylinder do my friend thinks it is what is causing the problem he said it is shot? And last question is there any way to free up the grease so it flows to where it's supposed to, I think that is the problem.
Thanx For any ideas
NYDOUG"
Thanx For any ideas
NYDOUG"
