"I need a distributor rotor fo
"I need a distributor rotor for my Johnson motor. The part number is 580338. I'd like to buy two if I can find them.
Also after the engine starts where is the "Auxillary Throttle" supposed to be set to. In addition I found instructions on setting the "Slow Idle" adjusters to the center position when starting the engine but a few pages later it had instructions on how to use them to adjust the slow idle. Do you leave them where they end up after adjusting the slow idle even when starting?
Thanks,
Bill"
Thanks,
Bill"
