model :J70TLCIM
after I came home from fishing I washed motor noticed both Trims started leaking fluid but not the tilt ram.
next day there was a small puddle of hydraulic fluid on my driveway.
filled it up with fluid turned on trim tilt up/down all work fine but the leak getting worse.
fluid is coming out from the centre of the End Caps rubber seal.
today I tilt the motor up/down and I got horrible noise coming from my tilt ram.
sounded like an old rusted door hinge very loud, checked fluid is full could it be air in the tilt?
trying to get seal kit.
just wondering how do I bleed the system?
thank you
thank you
