Johnson 70hp no spark
scottquinn
can anyone help have checked c
can anyone help have checked coils all oky replaced powerpack getting 0}.2volts to coil could thi be the stator the engine is a 1997}
"i would check all conn's
"i would check all conn's where they plug in,ck pack ground..all good,..u need a factory service manual to properly ck the stator and timer base..look for pinched/broken wires from timer base(sensors).."
i got readings fof stator it s
i got readings fof stator it should be reading 500ohms but got no reading when checked with meter do you think it is the ststor
"i prefer to do the cranking o
"i prefer to do the cranking output tests,..depending on problem...w/a peak reading volt meter."
"those are charge coil wires,.
"those are charge coil wires,..and actually has nothing to do w/charging system....yellow wires,.are your stator wires,..which charge batt...but,the entire thing,is called a stator."
