"My 1979 70 hp Johnson is runn
"My 1979 70 hp Johnson is running well now except there is a problem with charging. The console guage indicates around 12 volts, my volt meter measurement on the battery read 12.75 with engine off, then 12.57 with engine running. There is not change in the console guage if I increase the RPMs in neutral. The only other odd thing going on now is that the tach reads 10 rpms with key off, then with key on it drops to zero. With engine running it is operating normally. My question is this, how can I test to see what exactly is causing the problem with charging? Is the tach issue with key off an indication of another problem?
Thanks!"
Thanks!"
