Johnson 70 hp lower unti plug gasket
Riggo21
Can you let me know the part number for the gasket on the lower unit plug? It’s the plug that keeps the lower unit oil in.
I had a 1974 70 HP Johnson, needed the same thing. Went to a close by boat and outboard shop, they sold me a couple leather washers that they used on most of their engines. Worked great, and I have a spare or two in case I'd ever need a replacement. I know of no part number for them.
Select the year of your motor, then pick the HP. It will open a menu of all subgroups. Scroll down to gearcase.
You will see the drain plug & washer. The same part fits a ton of motors. If you have the magnetic drain plug, with a groove, the factory part is an O ring…Sierra sells 5 packs.
If the drain plug is a plain threaded screw with no groove it uses a flat washer.
However, the flat washer will also work with the grooved plug as it also has a flat surface on the head.
