G'day fellow boaties,
Just purchased a Johnson VRO 60hp 1986 model. Engine stalls shortly after starting, revs hard once started (with start throttle lever up). Pushing key makes sound (assuming choke solenoid engaging), but no mater what I do with choke/throttle cant keep her running. New plugs. sprayed carbie cleaner into throttle body. Fuel filter ok. May have been guilty of over priming oil bulb...oil in carbies? Whats the best way to check for sufficient fuel pressure. Any suggestions would be greatly appreciated. Cheers...Rob
