johnson 55 dies after running full throttle
killemall1983
ive searched dozens of forums and groups and not a single person can give me even the slightest answer.
this motor will start very fast. it will stay running forever in neutral. even at low speeds it runs fine, UNTIL i drive it full throttle.
once i drive it full throttle, and put it back in neutral it will die. then it wont start again unless i full choke it a few times then punch the throttle. once its been driven full throttle, it will never start the first time or run at low speeds again that entire day.
if i never use full throttle, like one lake where its no wake lake, it runs fine all day zero problems.
And the kicker is i have another boat, a tracker with a merc 40 that does the 100% identical thing
Test run with another hose and tank.----Perhaps install a new diaphragm in the fuel pump.-----And motors need a new water pump impeller about every 5 years.
Does spark jump a gap of 3/8" or more on both leads?---And post the actual compression test values here.---What elevation are you running at ?
At those elevations you may need to change carburetor jets.----Consult you local friendly shop.----They may have experience / know exactly what to do , to solve this issue.
That's why I'm asking here. Mm only has a few boat mechanics on the entire state and maor are over 2 hours from me. The only one close to me charges 3x normal price
