Johnson 50 hp
"1984 50hp Johnson. A good des
"1984 50hp Johnson. A good design but as with anything mechanical, problems can exist.
The very first year of the VRO with "no" warning system."
Ken did you check the little p
Ken did you check the little pisser thing for being plugged at its outlet?
Otherwise to change the pump unhook the gearshift rod under your engine and then drop the bottom end of your transome to change the pump.
8 bolts and one hides under the trim tab!
"VRO = Variable Ratio Oil. Big
"VRO = Variable Ratio Oil. Big plastic black fuel/oil pump that mixes the oil with the gasoline automatically.
(VRO Changeover Judgement Call)
(J. Reeves)
The VROs first came out in 1984 and have been upgraded quite a few times. In my opinion, back around 1988, they had perfected them but I think that they were upgraded even more since then. As long as the warning system is operating as it should, I feel quite at ease with them.
Some boaters have voiced their thoughts such as "What if that overpriced plastic horn should fail while I'm under way for some reason, and the VRO decides to fail five minutes later?" Obviously that would result in a big problem which really brings their fears into view.
The word "ease" is the key word though. If one has the slightest feeling of being ill at ease with that setup, then they should take the route they feel more at ease with. A judgement call each individual would need to make on their own.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store
(VRO Pump Conversion To Straight Fuel Pump)
(J. Reeves)
You can convert the VRO pump into a straight fuel pump, eliminating the oil tank and VRO pump warning system, but retain the overheat warning setup (and fuel restriction warning if so equipped) by doing the following:
1 - Cut and plug the oil line at the engine so that the oil side of the VRO pump will not draw air into its system. Trace the wires from the back of the VRO to its rubber plug (electrical plug) and disconnect it.
2 - Trace the two wires from the oil tank to the engine, disconnect those two wires, then remove them and the oil tank.
3 - Mix the 50/1 oil in the proper amount with whatever quantity fuel you have. Disconnect the fuel line at the engine. Pump the fuel primer bulb until fuel exits that hose with the tint of whatever oil you used. Reconnect the fuel hose.
That's it. If you want to test the heat warning system to ease your mind, have the key in the on position, then ground out the tan heat sensor wire that you'll find protruding from the cylinder head. The warning horn should sound off.
"pisser thingie is pissing a g
"pisser thingie is pissing a good stream, just thought that since the motor has sat up a couple of years it would be a good idea to change the water pump.
thanks for all the help and advice
Ken"
