Johnson 50 2001
mrthumper
I have just bought a Shetland
I have just bought a Shetland with a Johnson 50 outboard it starts fine but when i push down the fast idle lever to put in gear the engine seems to be reeving low and cut out thanks
"Check the idle set screw, may
"Check the idle set screw, may just need adjusting. Should settle to about 600 rpms in gear at idle."
Thank you so much for your hel
Thank you so much for your help im very new to boats well had it two days where do i find this screw
thats the 4 stroke fuel inj mo
thats the 4 stroke fuel inj model.
i dont see a set screw on parts list
i sugg a general tune up /de carb (seafoam)
"i think,..that would be a ...
"i think,..that would be a ............suzuki pwrhd...i am not familiar w/that one,but i would think it has a way to adj idle speed."
"spd limiter,is for low spd??.
"spd limiter,is for low spd??.how do u increase idle spd?.....god i mis those 80's eng's....."
"Engine idle speed is set by c
"Engine idle speed is set by computer. The only adjustment screw is for the IAC valve, and that is not to be tampered with unless You have it hooked to a computer/lap-top. The neutral limiter is there to prevent engine/cam/valves to blow to pieces when over reving unloaded.
Anyone that wants to maintain these engines should simply buy a FACTORY manual."
