Bulldogste
Hi,
let me start of by saying hello to all.
i have an issue with a 1979 Johnson 4hp outboard 4BR79D
i did phone my local boat shop but they were not interested as said there is no money to be made in small out boards, I was like cheers for that!!!
i went to start it the other night but had no joy, just for info it had been running fine the previous week.
started out checking basics and noticed it had only one spark on the top cylinder, to my horror I pulled the top off it and noticed it had points, i have not worked on anything with points for about 20 years haha.
stuff I have done to try and isolate the fault.
1. Checked spark plug leads. Continuity check switched spark plugs ect.
2. Switched coils and condenser over, still had spark on the top cylinder as before the switch. I was convinced this would have sorted it.
3. Removed both coils negative and positive wires and checked for resistance to the ht lead.
4. Gave the points a quick clean in sittue, sand paper then ran a bit of card through it.
5. Checked continuity at the points.
Any my help or advice would be greatly appreciated.
regards
steve
regards
steve
