"Hi to all
I am from Greece
"Hi to all
I am from Greece
I have a 40HP Johnson about 10 years old.My problem is with the oil injection.I use the boat not too much only in summer, so the boat had to stay unused for alot of time. When I try to fire it up, It is imposibble to start, I use the starter, and the choke but nothing alot of smoke and nothing.
The only way to start is to empty the tanks of the carbs. When I empty them both is full of oil.When I empty them, the engine starts at once, and I have no problem when I use the engine leaving it no more than 10 days.It works very well.
The problem is that in my engine it is very difficult to reach and empty the carbs, I have to remove the oil filter, and the oil injection pumb is in front, very difficult...
I am thinking 2 solutions
1) To remove oil injection or
2) To put a valve in the oil line to close the oil when I don't use the engine
I don't know it this helps, you are the experts and is there is any other solution?
If you propose, to remove oil injection, I have to put a new fuel pump ( because this one is oil-fuel ) or I can leave and this one? Is it possible to show me how?
And something else, One year I emptyed the tanks. I didnt started the engine, and in 45 days I tried to fire up it was not starting, and the tanks were again full, ( without starting the engine ), that is why I thinked to cut the oil line when the engine is unused for a lot time
Thank you in advance
Waiting for your answer
Leonidas
I am from Greece
"Hi to all
I am from Greece
Leonidas
