"Can someone help me with this
"Can someone help me with this. I have a 2000 40HP Johnson, the thing idles fine on the hose but when put in the water it will stall out. It will fire back up easily. It will stay running as long as I keep the carbs open a bit. I know the water puts back pressure on the engine but could this just be that the engine idle speed is set to low? I look at Seloc online and it shows how to adjust the idle, but it doesn't say which way to adjust the screw for increase/decrease. Also where do I hook a shop tach up to it? OR is there something else causing the idle issue? the bulb stays hard, has a new fuel pump. At WOT it doesnt skip a beat.
Thanks"
Thanks"
