Johnson 40 hp big twin outboard
karaokeb
Hi All,
*I have acquired one of the above which has good compression on both cylinders and the gears appear to work however I have the following questions to which I would like some information.
The shear pin on the prop is approximately 1/4 of an inch is this correct?
When the engine is in gear should there be any play on the prop if yes how much?
When looking at the engine from the back there is a plastic rod on the left hand of the flywheel which is not connected to anything but it seems to me should be connected to the gear change rod as when I manually move it it seems to hold the gear change rod more securely in place.* There is possibly a spring missing which holds it in place.
Any infomation regarding the above would be appreciated* - also is there a reference somewhere where the year of manufacture can be worked out from the serial number of the engine.
Again many thanks for reading this and any help provided.
Regards
Karaokeb*
There will be lots and lots of slop and this is normal !!--------------------------You have to post pictures of this " plastic rod " as your description is not clear. The old omc site Has pictures and catalogues, just for your enjoyment.
