70 in both holes is not terminal. Those little three horse twins are low compression by design, that's how you can rope one over without a decompressor.
What matters more than the number is that the two holes match. 70 and 70 is fine. 70 and 45 is not.
One thing to watch. A cold reading is the worst one you will get. If it runs, warm it up and check again. And hold the throttle wide open while you pull it, four or five pulls until the needle quits climbing.
Check your adapter too. Those rubber cone tips leak on a small plug hole and you read low. A threaded adapter that matches the plug thread is worth the few dollars.
Quick test if you want to know about the rings. Teaspoon of oil down the plug hole and pull it again. Jumps up 15 or 20 and the rings are tired. No change and the top end is probably sealing fine.
I don't have the JW-21 book in front of me so I won't quote you a minimum. But if it starts easy, idles and pushes the boat, compression is not your problem. Then I would be looking at spark and the carb.
If it sat for years, decarb it and retest. Rings stuck with carbon read low and can free up after a good soak. thanks
