Hi,
I purchase an older 14' Cresliner (1963) Powered by a Johnson short shaft, 35 hp (1983) with control, and my issue is the outboard motor won't stop. Start right up, idle well, but turn the ignition key to off position and it keep going, pull the kill switch, still going. I need to pull the chock to turn it off.
I install a new, made in the USA, ignition switch and a new kill switch. What could be the problem(s)?
Thank you,
Blommca10
Thank you,
Blommca10
