Hello,
My old 33hp Johnson started to make a very strange thing, while in gear and at half throttle, the motor moves fine, when i add a little throttle it gets in high rev and wont move anymore! It sounds like, when for example cars clutch is slipping, after i release throttle and put the throttle again about half it works again. This thing should not make sense, i checked the prop pin, and it was also Ok. Does anyone had such a problem, or knows, what can cause such an issue? The gear lever does not move, when it happens.
