Goodwrench
Hi everyone, new to forum. First off I am a mechanic, just not Marine. I repair light and medium duty equipment everyday. I pulled the lower unit off of my 33 HP Johnson 1970 due to oil leaking from the weep hole when running with muffs. I just bought the motor and he told me he put a new impeller in. Question #1 there is a o- ring at the top of drive shaft just below the splines in a machined groove that looks like it could be for an o- ring but the other end of the shaft looks the same and no o- ring. Does the o- ring belong there. Question#2 where the drive shaft comes through the water pump housing there is no seal or o- ring. Is the top of housing just open or is something missing. Question#3 shifter shaft bushing is shot are special tools required to remove and replace it. Thanks for any advice you can give me.
