Johnson 30TELCCE will start but will not run at full throttle
A
albert baker
Guest
Purchased used Johnson 30 hp.
Purchased used Johnson 30 hp. Motor will start fine and idle but will not run as I try to increase throttle. When it does run at full throttle and then reduced to an idle the engine stops. What should I do to trouble shoot?
first thing check/clean/reset
first thing check/clean/reset or replace plugs.
But I think probably a dirty carb is your problem.
compression/spark...carbs/fuel
compression/spark...carbs/fuel delivery( fuel pump/filters/etc)...timing adv as apropriate..
