Johnson 30hp water pumping problems
fishingconi
hi i have a 30hp electric star
hi i have a 30hp electric start for some reason it has stoped pumping water it was working ok till i tried it this morning no water coming out of rubber tube any ideas i thought impeller where is the impeller on this engine and how hard is it to check & replace if needed
regards ian
"USE a piece of wire,weedeate
"USE a piece of wire,weedeater string,toothpic,etc,to clear the plastic nipple on discharge hose...if eng is overheating,..replace wtr impeller."
thank you for responding i tri
thank you for responding i tried a piece of strimmer gut and pushed it right in as far as i could. that solved the problen thank god i thought it was going to be costly
