D
David Pruett
Guest
"I have been having some real
"I have been having some real problems with this motor. It sounds like trash in the carb. However, I have completely removed the carb and cleaned out all the ports, I drained my tank and installed an in-line fuel filter, new lines everything.
Okay, the problem is when I crank the motor, it cranks fine and idles. But when you throttle, it just boggs down and goes 6mph. Once you put the load on the motor is won't go but you can rev it up while in nuetral by opening the butterfly valve on the carb. It does not cut off though. You might idle like this for a mile and then vroom, it just takes off and runs fine. But usually takes a while. Sometime it never runs right and you end up loading up and going home.
One day we tried revving up the motor and trying to suck out any trash that might have been in the carb. it worked, but not everytime. But we've since then cleaned out the carb.
i cannot understand how it will run fine one day and the next morning it starts all over again.
Does this sound like a power pack problem or maybe even a coil problem? If anyone has any suggestion that would be great."
