The motors not circulating water. I’ve taken the lower unit apart and looked at the impeller it seems fine I did an impeller test of the lower unit with an electric drill and it pumps water at the lower unit site. I’ve cleaned out the tube up the shaft to the head. For the life of me I can’t find the P hole on this thing, there is a hole On the bottom aft end of the cowling which I suspect is the exit hole for the water but nothings coming out. It’s a collapsible shaft so I’ve used an air compressor both directions from the middle of the shaft to the impeller and from the middle of the shaft up to the head.
I guess two main questions one where is the P whole and two why isn’t it passing water. It didn’t look terribly gummed up with guck so I don’t think the head is all gummed up. The motor itself runs like a charm. Hope somebody out there can you give me some ideas thanks Hope somebody out there can you give me some ideas thanks.
