Johnson 25rk75 gear skipping
dwymik
I have a Johnson 75RL75b seria
I have a Johnson 75RL75b serial number E4353362. When in gear the motor jumps like a gear is skipping. It happens at the same rate increasing as you speed up. Anyone have any advice I would like to fix this myself as money is tight. I have average mechanical skills. I am guessing that a gear in the lower unit has to be replaced. Thanks for your help.
Mike
I had the same problem on my J
I had the same problem on my Johnson 225 with a 1991 gearcase. The sliding clutch dog gets worn out sometimes. Problem is that you have to dissassemble the entire unit to replace it. First I would try to adjust the shifter cable to give you more pressure in FWD. Be mindful of adjusting it though because as you add more to the FWD you will take away from reverse.
The total lower unit rebuild is not too bad of a job. You just have to be mindful of all the parts. You can get a heavy duty aftermarket gearset for the lower unit off of the internet for less than the original Johnson parts. Seloc has a nice online manual that will walk you through it. It is a pay service.
That lower unit is very common
That lower unit is very common---Many used ones and parts available. Needs a new clutch dog and maybe a forward gear.
"(Jumping Out Of Gear - Ma
"(Jumping Out Of Gear - Manual Type)
(J. Reeves)
This pertains to lower units on all OMC manual shift outboard engines, or any OMC engine with lower units defined as a Shift Assist or a Hydro Electric Shift unit which incorporates a "Shifter Clutch Dog".
Within the lower unit, splined to the prop shaft is what is most often referred to as a clutch dog, hereafter simply called dog. The dog has at least two lobes protruding from it on both ends, facing both forward and reverse gear. The forward and reverse gears also have lobes built into them near their center area. When the engine is running, in neutral, the gears are spinning constantly via the driveshaft being connected directly to the powerhead crankshaft, but the propeller does not turn due to the fact that the dog is centered between the two gears, and the dog lobes are not touching either of the gear lobes.
When the unit is put into either gear, shift linkages force the dog (and its lobes of course) to engage the lobes of the gear. The lobes of the spinning gear grab the lobes of the dog, and since the dog is splined to the prop shaft, the propeller turns.
The lobes of the dog and gears are precisely machined, most with right angled edges that could be installed in either direction, and some with angles slightly varied that must be installed in one direction only (one end only must face the propeller). Dogs that can be installed in one direction only, if reversed, even if the dog and both gears were new.... would jump out of gear almost immediately. Keep in mind that the lobes are precisely machined with sharp angles!
Due to improper adjustment or worn shift linkages, but usually due to improper slow shifting, those precisely machined sharp edges of the lobes become slightly rounded. Now, with those lobes rounded, as the rpms increase, the pressure of the gear lobes upon the dog lobes increases to a point whereas they are forced apart (jumping out of gear), and due (usually) to the shift cable keeping tension on the engines shift linkages..... the unit is forced back into gear giving one the sensation that the engine has hit something, and the cycle continues.
Some boaters have the mistaken belief that shifting slowly is taking ixt easy on all of the shifting components..... Wrong! Shifting slowly allows those precisely machined sharp edges of the dog and gears to click, clank, bang, slam against each other many times before they are finally forced into alignment with each other..... and this is what rounds those edges off! The proper way to shift is to snap the unit into gear as quickly as possible.
When time permits, visit my store (copy/paste) at: http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store"
Just wanted to follow up on my
Just wanted to follow up on my earlier post. I just finished my lower unit rebuild this evening. Everything seems to be working great. I am going to take it out on saturday. For your reference I will share how much I spent on it.
$450 HD Gear set and clutch dog
$50.00 Water pump kit
$80 Gearcase seal kit
I had to buy one tool. I needed a puller to get the bearing carrier out. A simple and cheap timing gear puller from my local auto parts shop worked great.
$30.00 Primer and paint
Since I run my boat through some nasty stuff my gearcase looked a little bad. I decided to re-finish it while it was taken apart.
Total = $610.00
This is half of what a rebuilt one would cost. Good luck in what ever you decide to do.
