"Smoke eh?
Compression was
"Smoke eh?
Compression was what?
Good spark?
50:1 fuel mix?
Plugs looked like, before, after it ran?
It's getting fuel to where, fuel pump, carb, cylinder?
Carb set per Joe's spec's?
If it is just a matter of adjusting the carb, these adjustments as Joe describes, done correctly does work. The first 1-1/2 turn is close enough to get it to run, unless the idle(rpms) is set too low. Once you find the place where it will run on the idle screw, the rest of the adjustments are fine tuning, and need to made carefully and slowly, so wait 15 seconds or so in between movements to let the motor catch up to what you're doing. Some smoke when you run in a tank is ok, but if it smokes while you're out on the lake is a different thing. Set your carb, and I think it probabaly just needs to be run for awhile to blow out the cobb webs."
