Hello!
I`m in desperate need of help for my johnson 225 VRO (j225plced)
Bought this crap with "sneezing" problems with given an easy fix! But hell no!
First days with boat in water was with idle sneezing, mostly the engine ran ”OK” but sometimes it just loosed all power and wont get up on the water!
Started with troubleshooting..
Found that it have been carb fire before, melted plastic in air box and som carb..
-Cleaned carbs with new needle valves.
-Compression OK
-Disassembled intake manifold
-Inspected reeds, drain valves, gaskets
-Glass cleaned throttle bodys and adjusted
-Set the timing at idle, unsecure about linkage is correctly adjusted
-Changed timer base, powerpack. reglued new magnets, sparkplugs, wires and coils.
-New fuelfilters
-Primer are OK
Still its running like **** and looses power, plugs for cyl 2,3,6 are dry/brown cyl 1,4,5 are all wet! WHY?
There is alot of bluesmoke from the fumes!
Would be very glad for some tips!
-Compression OK
-New fuelfilters
-Primer are OK
