Hi all I have a Johnson 20 hp 2 stroke out board that is running quite lumpy and after inspection of the carb it looks to me like the needle that runs vertical through the centre of the carb is poking out the bottom of the main jet which means I can remove the main jet as it's in the middle of the flats for the screwdriver is this normal ? Thank you in advance
