Hi,
I have the same motor and have had the same issue for the past two years. This is really coincidental because I have not checked in on this forum in a while, and I happened to go to the local marine service center down the street today to get an H2O / fuel filter cartridge and plugs, and I asked the long-time owner about this same issue.
My motor is carbed, I assume yours is as well. My motor will be OK at idle and in low gear for a time, then suddenly it will stall out, or bog down when I go to give it gas (throttle up). Whenever it stalls, it will start right back up. It runs great when the RPMs are mid to high range. It's just that idle / low RPM period where I get the stalling or bogging.
Now, I'm not a marine mechanic, but I have pretty good mechanical comprehension. The way the guy explained it to me today when I asked him was, in his experience, that the "old" carbed 2 stroke motors are really finicky at idle. Everything has to be set just right in the chain of fuel movement through the carbs, or else they can flood and get choked out temporarily. He said that with these motors, they have gone to some plastic components that don't neccesarily do too well with warping, ethanol in the fuel, etc., over time. Just the nature of the beast. He said you really have to do some "old school" carb adjustment to fine tune the system. This involves knowing what to look for and in what sequence things are happening. Also involves in-water testing - can't fix it just on the hose.
I'm hoping to get through this season and have him take a look in the Fall. I would appreciate any other opinions or comments on the subject. Thanks and good luck with your motor.
Dave
