vellmichael
Hi,
I have a 2004 Johnson 140 4 stroke engine and is currently rigged with the standard BRP tacho with system check lights incorporated. I would like to add a conventional temperature and oil pressure gauge to my current set-up to be able to keep a real time monitor of the situation whilst running.
Has anyone done this before? Is it possible to eliminate the BRP tacho + system check and rig a normal tacho, temperature gauge and oil pressure gauge?
or else if possible I could keep the original tacho + system check and add the other two gauges.
appreciate any input you might be able to provide.
thanks in advance,
Mike
thanks in advance,
Mike
