Model is J4RSIB.
Started up, but with gas leak coming from Carb
I took the carburetor apart and cleaned it excessively. Put back together. Started but with still with gas leak.
Next, I ordered the OEM kit and replaced the needle, seat, gasket and float, removed and cleaned the high idle screw and cap.
Did not start or turn over, gas leaking once bowl fills with gas. Small drips, appears to be coming from main bowl gasket on the fuel intake side but that is new and tight (gasket is not kinked).
The fuel hoses and connections have all been checked and no leaks from there. Using 50/1.
What could I be missing?
