Johnson 2000 200hp not starting - carbs were cleaned
offshoredude
I have a 2000 Johnson 200hp outboard (model# J200plssc) that I bought used (came on a '79 kencraft) and it is giving me inconsistent results. First, it would crank and never turn over. So, I replaced the spark plugs. I was then able to get it to turn over, however it was smoking really bad and died within 5 seconds (even when giving it some throttle). I then removed the 6 carburetors and the carb intake/throttle body. I took them completely apart, sprayed very well with carb cleaner and replaced all gaskets. I also replaced the needle and the float. This didn't seem to change much other than now it "occasionally" starts a little easier but still dies after a few seconds. I noticed the ball pump wasn't getting hard so I replaced with a new ball pump from Auto Zone. It seems to be getting hard now. Then I tested with new fuel (93) and some Sea Foam to try and clean it out. I also did a compression test and all cylinders are firing around 90 except one which is firing around 80 psi. This was the only time that it ran really well (obviously smoking a ton because of the sea foam). The next day I tried to run again using the new fuel and I'm back to the same results where it's very hard to start and when it does it just dies (a lot less smoke now though). So I checked the fuel filter and saw there was no filter in it and there was some gunk built up in the filter housing. Went to Auto Zone, they did not have the same filter but another filter that fits the 3/8" fuel line so I installed that - It is a significantly bigger filter just an FYI. I also replaced some of the fuel line running from the main fuel filter on the boat to the ball pump and to the Fuel Pump with brand new line. Same results except now it seems there is some fuel leaking from a jet in the throttle body itself (not the carbs). So I have a few questions...
1) Could the fuel be leaking from the throttle body because the new fuel filter is significantly larger and maybe too much pressure? Could this happen if I just overpumped the ball too many times?
2) Does anyone have any recommendations for next steps or suggestions on what might be the issue?
All help is greatly appreciated as I am completely stuck with this motor that I have never even been able to use!
