Johnson 1988 70HP VRO2 4 wire.
Help,
The fuel intake pressed plastic male end that goes into the VRO fell out. The male plastic goes into a female plastic on the pump itself. I cleaned it sanded it, used alcohol on it and tried several glues. Seal All and others that said they were gas tolerant. Lasted a few minutes and fell off.
Where can I find a fuel pump only to replace the VRO system. I will gladly mix my own gas and oil. Can't spend $400 plus for a new VRO pump and chance it going bad. Or does anyone know of a glue/adhesive/sealant that will weld the two plastics together and NOT leak and hold up to constant gasoline.
Perch fishing on Lake erie is slipping by me.
HELP!!!!!!!!
Gator
Install a pump that is pre VRO.--------------Order one for a 1983 70 HP.------Then mix fuel at 50:1, cheapest and best solution.
