Johnson 1975 135 hp Power Pak
the_worm
"One day my boat worked fine,
"One day my boat worked fine, the very next day from the start it did not have enough power to get to plane. I suspect the Power Pak as I have had to replace this 3-4 times over the last 15 years. Is this normal? Or should I be looking for a deeper problem. Also when accelerating it seems to have a short dead spot that I can't locate. Once I get past it the engine seems to run fine."
This sounds more like dirty ca
This sounds more like dirty carbs than a power pack. Typically you either get spark or you don't. When was the last time the carbs were rebuilt?
