Johnson 1968 40 hp Rebuild ( model RD-30A )... need info pls
vvulture
Hey guys,
In the process of rebuilding this 1968 40hp motor.
Can anyone help me with information regarding torque settings for the various components ? Especially the head bolts, flywheel, con rods, crankcase etc etc...
Thanks guys,
Your help will be greatly appreciated...
Thank you bobbyc... much appreciated.
However, is there any chance you could repost a somewhat larger image ? It is very small and im having a hard time reading the numbers.
Also, will these be ok for the 68 model ? I can see that the engines are almost identical...
Thank you
Hope this help
1968 40hp
Flywheel nut 100-105 ft. lb.
Connecting rod bolt 29-31 ft. lb.
Cylinder head bolts 14-16 ft. lb.
Crankcase to cylinder bolts upper and lower 12.5-14 ft. lb.
Crankcase to cylinder bolts center 13.5-14 ft. lb
