" Hello -
I have recently acq
" Hello -
I have recently acquired a '63 18 hp Johnson. It runs only on the lower cylinder. Both cylinders have similar compression, spark at both cylinders. Disconnecting the upper plug wire while running makes no noticeable difference, disconnecting the lower stops the engine. I've swapped plugs with no change. The upper cylinder is getting fuel - the plug is wet when removed. Any suggestions on what to check next?
Thanks!
Mike "
I have recently acq
" Hello -
Thanks!
Mike "
