Johnson 18 HP FD15 motor
photograph4
"How do I use this motor?! hah
"How do I use this motor?! haha i just got it all fixed up, i have posted some stuff about it before. and i went to use it last night and It wouldnt run for more than 10 seconds (a strong clean 10 seconds though, no putting or anything) but the it jerked 2 or 3 times and shut off- any ideas re: settings etc."
"I guess the simple answer is
"I guess the simple answer is that your motor is not getting fuel. Not knowing the history of your motor, what you have done to it already, it sounds like the needle valve in the carburater is stuck/misadjusted. It also could be that the fuel pump is shot. The carb is maybe just dirty/clogged, fouled in some way. Unlikely that the slow/high speed jets are fouled, the 10 seconds that it does run, it runs good. Heres a carb adjustment per J. Reeves give it a try, although it may not solve the problem, it's good info.
Carburetor Adjustments - Two Adjustable N/Vs)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle va /lve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, wating for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway."
