Johnson 175 shift rod screw location?
buzz54
I am trying to replace the impeller on my 1989 johnson 175 and I am trying to find the screw that holds the shift rod. I looked in the manual but the picture is not very clear. Dose anyone have a picture of the screw that I am looking for?
From the starboard side of the motor use a strong flashlight.-------Look under the bottom carburetor.----Look for a horizontal screw with a 3/8" hex head and a slot for a plain screw driver.----Can't find it , then remove the bottom carburetor to make it easy.
Thanks for the suggestion. I removed the lower carb and was able to get the screw out.
