Johnson 175 hp gear box
Skip R
I replace the water pump in my 175hp 1996 Johnson outboard a while back and while work on the gear box after puting it all back together took a hold of the prop and lifted it up and I noticed that I could move it a slight amount up and down, not a lot but a little and it got me to thinking ( which is a little scary) , is this normal. In the back of my mind I am thinking that I shouldn't have any play back there but I just dont know for sure. Never have had any water in the gear box buy the way.
If you're actually saying that the propshaft could be moved up and down (not in and out), that would indicate a bit of play (wear) in a bearing. A few thousands of a inch probably wouldn't matter but if it got to a point where the movement would approach say 1/16".... that would make me a little nervous. Keep your eye on the gearlube and should you start to encounter a water in the oil problem, at least you'll have a pretty good idea where to start.
