D
David Lithgow
Guest
" I just bought an '76 Joh
" I just bought an '76 Johnson 15HP for a small duck skiff. It starts on the first or second pull and runs very smooth. The problem is that it won't push the skiff on to plane at WOT. I don't have a tach attached but I'd be surprised if it is getting to 3500 RPM. I guessed carb trouble and got a rebuild kit. After tearing it down I find no obvious problems in the carb. The high speed jet has a coating of varnish but both it and the riser tube are substantially open. I checked compression with the following results. 60-80-94 #1, 60-80-89 #2. Those are the readings with each pull of the starter rope. Is the compression too low? The points are clean and right on the .020 spec stamped on the housing. The prop is a 10x5 work boat prop which should have over-reved. I've got a 9x10 weedless but I'm not sure the problem is prop related. Any ideas or things to check out would be greatly appreciated. "
