Hi All,
Hoping I can get some advise on diagnosing my outboard problem.
Firstly, I think my outboard is a 90's model - Built in Belguim - Model: BJ15BAENM - Doesn't seem to match Models listed.
I bought the motor from a guy & he told me it had a new water pump & impella.
Also mentioned the telltale does not put out much water - I've only seen a few drops of water.
Problem:
Motor starts first time - no problem,
first time I took it out, got it up to top speed for about 5 mins, then it just dropped to idle.
tried to accelerate again, gets to about half throttle, then drops to idle again.
Puttered home, checked fuel connections, replaced the fuel connector on motor in case it was sucking air.
Tested motor on trolley, seemed OK.
Second time out, putter out, then accelerate - same problem. Gets to about half throttle, then drops to idle speed.
I'm thinking its either a fuel/carb problem or possibly overheating?
Would the motor restict to low throttle if its overheating (thermostat)?
(Although when I got it home and flushed(engine coldish), it drops also).
Possible the water pump/impella wasnt done or badly done?
Thanks in advance.
Cheers.
PJ
Problem:
Thanks in advance.
Cheers.
PJ
