L
Lee Simmons
Guest
"Hello all! I just found this
"Hello all! I just found this board, and it seems to be full of helpful people who know their stuff. So here is my problem. I am somewhat experienced in auto mechanics (learned the basics in high school then practiced shadetree mechanics) but know nothing about marine engines, especially 2 strokes. I bought my first boat about a month ago. It is a 1990 model fish and ski with some cosmetic defects but seemed to be in good mech. condition. Basically a good "starter" boat for no more than I paid. I think the motor is also a 1990 model. The model # is VJ150SLESB if anyone an tell me for sure. When I looked at the boat it started quickly and idled smoothly with the muffs on. The first 2 times out, the boat ran fine. It started with no problem and each time went for about 2 hours with some low speed and some high speed cruising. I kept the original tank of gas which was about 3/4 full. Each time using it down to about 1/2 tank and refilling. The third time it again started right up and idled smoothly away from the dock. I got up on plane for about 15 seconds then started losing power and backed off the throttle. It cut off but started right back. It runs fine up to about 1/3 throttle then bogs down and will die if I don't back off. I checked the fuel line and filter, seemed to be clear. I pulled the plugs. They were all about the same wet with some oil on them. Not sure how much oil residue would be normal in a 2 stroke. I plan to replace them before going out again. Just looking for ideas on what to check and if it is the plugs, how to prevent it next time. Oh and also what sounds to me like a silly question. When I uncovered the carbs, there was no air cleaner! Should there not be one? Sorry so long but I wanted to give all the info I could."
