1992 Johnson 150hp (tj15oglenc) is starting up and firing but then just shuts down right after startup. When I push the key for the primer solenoid in and the motor picks up RPM and runs. The carbs have all been cleaned, because I had a lean condition and I replaced the rubber seals covering part of the idle circuit. I verfied the high speed and low speed passages were clear. The only thing I did notice was that on 3 of the 6 cylinders the float bowl is leaking a small amount from the rubber seal, can this cause the problem I'm having?
If the high speed jets were clogged again, would my motor still idle or does the high speed jet feed the low speed circuit?
