gman 92 johnson
I have a 1992 Johnson 150 Silver Star Series, unknown total hours, but I know I have put over 200 on it in the past 3 years..Have a little leakage problem..after running the engine the past few times(average 3 hrs) engine runs fine ,starts fine, put after shutting it down it will leak an oily residue out of the cowling, leaks more when engine is tilted for towing..residue is green oily film, thicker than the pre-mixed gas I run(50-1)carbs don't seem to be bogging down like floats are stuck or needle and seat stuck..but it will leave a trail of oil down the front of the lower shaft housing down to the cavitation plate..I have rebuild the carbs in the past year and had to clean 1 or 2 when the needle and seat got stuck and they free-flowed...any ideas what I should specifically look at or for or should I just rebuild all the carbs again..there was a little bit of gas mix drip hanging off the bottom of a couple of the carbs when I pulled the cover off after last weeks useage...any insight would be appreciated...
