I have a Johnson 115Hp V4 outboard which I am pretty sure is a 1988 although it does not have its ID tag. It is a premix engine and has not had a VRO pump taken off it. I have ordered parts for it in the past for a 1988 which have fitted but maybe I have been lucky. The welch plug has some numbers on it but i'm not sure if that really can ID the model, those numbers are C0400119.
Can anyone please advise me on the timing/carb sync set up as it is currently only revving to 3500 with the throttle lever in the full speed position. The carbs are not full open at this setting and i'm not sure if they are supposed to be. I am a motor mechanic by trade so am capable of the adjustment/alignment if I have the data. I'm not sure of the size prop on the boat as I can't see any figures although the prop shows signs of a repair at some time. The boat weight approx 700KGS and at 3500rpm it is travelling at 30mph. The last bit is just in case it helps.
Thanks for any help. I would put it into a shop to have it done but here in the UK, finding a decent outboard mech is a very rare thing and I find that if I do the job myself, I know it will be done right.
