E
ed
Guest
" Joe,
Pressed out the upp
" Joe,
Pressed out the upper crank bearing and called the manufacturer, Torrington. They said that it is a propretary bearing and is only available to OMC. can you believe that...... . anyway will a bearing assembly from a 1986 90HP work? can you tell me what years have the same bearing assembly?thank you "
Pressed out the upp
" Joe,
