Johnson 115 throttle linkage adjustment
beauscout
"I have owned a 1993 Johnson 1
"I have owned a 1993 Johnson 115 for about 7 years. It has always been difficult to start the first time on a day when I take it out. Subsequent starts during the day have never been a problem. Recently, I noticed that as I moved the throttle control to the start detente position, there was absolutely no movement of the throttle linkage in the engine up to that point. Shouldn't the carb butterflies be open just a bit when starting as opposed to being closed entirely? Assuming so, I adjusted the linkage so that it moves slightly as the throttle lever is placed in the start position. I have yet to test the engine from a cold first start since making the adjustment as I have not had a chance to get the boat out again.
I have a Clymer publications shop manual for this engine, but its illustrations are muddy photos and poor descriptions. Can anyone tell me where I could find good throttle linkage documentation and diagrams, either on the web or in printed manuals?
Thanks for all responses."
"Hey Bill...Sounds like you ha
"Hey Bill...Sounds like you have got your linkage set about right..just as the timer plate starts to move, the carbs should start to open...Any dealer will have or can get the manual for your motor,,perhaps some one on here will have the pics/info that you need..."
May be you should not adjust t
May be you should not adjust the linkage but the throtle cable. If you adjust the linkage you may un-synk the whole engine.
"I have a 1995 Johnson 115 60%
"I have a 1995 Johnson 115 60% loup charged
ocean runner.great motor,but since i bought it
the right lower carburetor had a slight leak
out of the bowl at some sought of ball check
looks like a little bebe.but now the bebe came out leak is worst,still runs great, but when
starting it i have to pump fuel line ball.looked
at carburetor kits don't see the part in them
could i just plug this hole?"
