motorboater
"I tried to start my 1999 John
"I tried to start my 1999 Johnson 115 60 degree looper one morning and all I got was a bump like it was going to start and that was it. Did a spark test and it sparked once and that was all. The battery is new and charged up.
I did a resistance test on the stator and I'm not sure if I did it correctly or not. When I test the brown wires in the four pin connector that goes to the powerpack with an ohm meter there was no continuity to ground.
I was getting some voltage out of one those brown wires when I did a crank test, I don't remember the value, I think 1.5v, but as I understand it I should not get any voltage from the brown wires, only the orange ones.
thanks in advance"
thanks in advance"
