Bigjohnson115
My motor trims up fine, but it will not lower without using the release screw. I have reached the relays, drained and replaced the fluid. I replaced all the valves, or check valves, one appeared to be under high pressure when I removed it. The motor works going up and makes the same noise when I try to go down. None of the connections are leaking so it is holding pressure. I have bled all the air out if the system. Any help would be great.
