"Hello, I hope someone can hel
"Hello, I hope someone can help with some questions on this motor.
problems I am experiencing other than the shifting/reverse issue covered with this type of unit are as follow.
When starting, the fuse blows, it cranks ok. Is a 20 AMP fuse required ?
Question 2
Tracing the wires from the Throttle control box so I understood what was going on with the shifting problem, I noticed a brown wire that went into the bottom right cylinder.....it is not connected but has a spade tip on it and rests in the engine compartment. I am thinking its some sort of accessory because in the Throttle control unit, the same wire just sits there. What is it ?
Question 3
Gear oil issue, I drained the oil and replaced with proper oil. The color of the old oil was like a butterscotch with a milky texture.
I was told this was because of water contaminating the lower unit. thinking about this, would it be correct in assuming, if water is entering the lower unit, would this possibly be the problem with the shifting since electrical components are located in the lower unit.
Any help would be appreciated. I just wanted to know because I would have liked to run the boat once or time this fall with an overhaul in the winter.
Liv"
Question 2
Question 3
Liv"
