With an ohm meter.Need help trouble shooting the electric start on my 1984 9.9 hp Johnson Seahorse. Starter test ok and push button is good. How do you check the neutral switch? Is there any other components in the start circuit I should know about? Thanks fro any and all help.
Model # is: J10RCRA. I have ohm both switches, the wiring harness and bench tested the started. If the pics don't come through let me know and I will resend.With an ohm meter.
Do you have 12v on red wire at terminal strip? Do you have 12v to and from n/s switch while pushing start button when in neutral?Model # is: J10RCRA. I have ohm both switches, the wiring harness and bench tested the started. If the pics don't come through let me know and I will resend.
